way2sl0
I got my setup installed tonight and set it up.
re srx 15, 3.5cuft ported 30hz, alpine mrp-m650 @ 2 ohms.
Needless to say I was coming from a single 10" P1. I turned the gains to about half ( my sony deck has puss preouts, like I mean 2v at clipping I sware ) so this was way the **** down. I listen at -10db on sub channel and its sounding boomy and loud tho. The 15" moves so much air just by barely moving that it overwhelms the front stage at low volumes. ANYWAYS.
I turned it up slowly, and started hearing mad distortion etc, thinking **** im bottoming out the woofer. Pop trunk and sub is barely trying ( Imo, maybe it is moving alot I dont know, id have to see an re srx 15 video, or I can shoot one and you guys can let me know how hard its trying? ).
I know this setup doesnt compare to most of you but for me it is ridiculously loud, and I matted the pieces on the trunk even, and the bumper sounds like its going to fall off asap.
I think even though it sounds so bad in the cab when I turn up the deck sub gain, ( not the amp gain still at half ) is because everything is flexing, because when I pop the trunk the sub is barely trying. Is this possible or am I infact bottoming out the sub? It says 18mm xmax so I am thinking it isnt bottoming out. What should I do?
