Sold holy ppi amp FS
thegreatestpenn
lazy genius
yes I said holy. why? the amp has a hole in it (along with a good amount of scuffs). Despite its ugly cosmetic appearance, it works great. its on the verge of blowing my little coaxials its on. The model is the PPI pc1400.2 couldnt find much info on it but I believe it is 75x2@4ohm, 150x2@2ohm, and 400x1@4ohm. dims are like 12"x9"x2.5". Comes with plugs. works fine, its in the car as we speak. I'll do 75 shipped on it. I won't even consider going down on the price until my next amp comes in. Hit me up if interested, cya
Interesting....
I thought the first digit in PC class denoted the channels. The rest of the numbers represent the wattage @2ohms. The dark grey PC series amps used the 4ohm rating in their model numbers. (the earlier version of this same amp would be PC1200)
PC1400.2 = 1 channel, 400 watts ( the .2 denotes the 2nd generation power supply)
Or :
PC4800.2 = 4 channels, 800 watts @ 2ohms
http://ampguts.realmofexcursion.com/PPI_PC4800.2/
PC1800.2 = 1 channel, 800 watts @ 2ohms
http://ampguts.realmofexcursion.com/PPI_PC1800.2/
PC2300.2 = 2 channels, 300 watts @ 2ohms
http://ampguts.realmofexcursion.com/PPI_PC2300.2/
All mono Powerclass amps can be run highpass, lowpass, or full range. They are class A/B amps, not class D and therefore can operate at higher frequencies.
um ok interesting info, if you don't plan on BUYING then what is your point???? do you have a manual????
bump
My point was to correct the gross misinformation you presented about an item you are selling and claim to be familiar with. Maybe this will keep the next buyer from being totally disappointed with their purchase and maybe save you a headache when the buyer finds out it doesn't do anything you claim.
Good luck with your sale and here are the specs:
Output Power:
4 Ohms 1X200W
Output Power:
2 Ohms 1X400W
Output Power:
4 OHM-MONO MONOBLOCK
THD: 0.02%
S/N RATIO: 115 dB
FREQ. RESP: 4.5-100K
I/P SENS: .15-12V
DAMPING: >500
DIMENSIONS 2.25” x 8.9”: x 11.75
QBASS EQ: QBASS
X/O SLOPE: 12dB/OCT.
X/O FREQ: 20-5k
X/O TYPE: 2 WAY
FAN? NO
thegreatestpenn
lazy genius
thegreatestpenn
columbus
thegreatestpenn
