Hmmmmm
i have never heard the sub in real life but just ran it through bbp and win isd and they both show that the sub should play very well as far as sq in a 2.584cu ft @28.44Hz, again that's just software calculations and not actual experience with the sub. the sub does look well built il like the low qts and power handling. plus flat cones always look sexy.
are you speaking of the ARC sub? Flakko can get some BADASS deals on a couple US Amps and boy does that AXTU600 tube amp seem amazing! its soooo sexy : ).
two of these. that is the MD41, i will most likely run the MD42.
and also
1 of the MD1's
i want to run an active three way setup. no rear fill, and some ARC subs, or Eclipse subs. What is a good three way setup I can get for around 4-500 all together, or squeak, can you help me piece one together? scratch the 2 4 channels, im only going with one, if that can run an active setup.
I have 1 flatline hooked up to a kar 900.1...no complaints at all. I'm still working with a stock HU and stock rear speakers with Kappa components up front (no amp). I listen to rock mostly and I'm impressed with the responsiveness, and of course it's loud.
bad *** dude. ever put some lyrical rap in it? not lil jon or slim thug. something more "indi" and see what it does? some of those beats have some tricky sub lines in them. they are very expiremental in that style music.
I really haven't pushed it much. I have the bass set to -3 on the HU and I only keep the bass control knob (came with the KAR 900.1) at the 1/2 or 3/4 mark. It drowns everything out when it's at full power, and that's with rock, I'd probably be turning it back more with rap. It's in a ported box that was made to have 1.8 cuft space like ARC has on their site.
saywhat?
satx120, jealous?
saywhat?
H'Burg Mississippi!
ZOOM 3
michigan born
    May 14, 2026
michigan born
    May 14, 2026
