hmm...
craigzter
erm..hello.
what do you guys suggest I get?
I have a ported box sitting in my bedroom that is 5 cu ft. tuned to 37 hz that housed my two 12" ample audios. Since I am trying to get rid of my ample audios, what other subs would sound good in this enclosure? Money is not an option.
p.s. Once I find me a more reliable job I am going to go all out on a new build for my blazer, leaning more toward SPL more than SQ. I am either going to be using the same box as mentioned above^^ OR I am going to wall it off:)..
but I just need suggestions on subs. IF I use my previous box, i will need two 12s. If I go for a wall I am wanting 3-15s or 2-18s.
LMK what yall guys think!
tyia
//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif//content.invisioncic.com/y282845/emoticons/wacky.gif.cf4a48f9e6dfe9504ffd2c946fd2f340.gif:smokin:lalalala..//content.invisioncic.com/y282845/emoticons/fart.gif.9285a21c4a53b1a914c9dedbfcf9d894.gif//content.invisioncic.com/y282845/emoticons/silly.gif.3549b64aaa5b6729eb8e865319a3234f.gif//content.invisioncic.com/y282845/emoticons/read.gif.ff512c499c00ed3faae9a20f4b088b29.gif
12" Mach 5 audio SPL with a 4k amp pushing the pair
12" CVR might work in that enclosure
you straight up say you are gonna maybe do a wall which woudl be a whole different set of subs or you want recomendations of twelves, s oyou are asking for 12 that will work in 5 cubes or subs that will work in a wall, 15's or 18's so to answer you anything from this list
Mach 5 SPL 15" !!!!
Sundown Nightshade
Cactus sounds 18"
Fi 18" BTL 18" Q has much more Xmax but cant handle the power.
Pioneer SPL 3000
Atomics still get ****ign loud
AudioQue 18"
kicker Solo 18"
DDZ 18"
power these with a kicker Warhorse, strapped Sundwon 3000D, RF 15K, Stetsom 7KD, DDZ series amp.
Good luck and get a bigger alt 4-6 runs of 0/1 guage 3-5 HC2400's batts and you just gotta build your enclosure, maybe some sound deadening.
you need to ask one coherent question at a time here.
i asked two:p
but thanks for the input, I am really thinking about the btls but I see tooo many people using them in wall builds and stuff.
But right now im not worrying about the wiring and stuff yet, until I have gotten my subs. That's probably not the route I should take but, it should be ok?
Anyhow, I wont be starting this project right off the bat, its going to be a little bit. Probably be around mid june or so before I start.
Im open to any suggestion. Its a close race between these three, 18"DDZs, BTLs or the Mach 5 SPLs. Off to find more infos:D
Thanks again, skateboardkid!
craigzter
erm..hello.
craigzter
sville, ar
craigzter
