HK4000d & Kicker ZX1000.1
wink2069
MA Audio HK4000d
Kicker ZX1000.1
HK4000d
•4000W Digital Class X Competition Mono Block Amplifier
•RMS Power @ 14.4V
◦1800W x 1 @ 4 Ohm
◦3600W x 1 @ 2 Ohm
•RMS Power @ 17.0V
◦2000W @ 4 Ohm
◦4000W @ 2 Ohm
•Temperature, Voltage & Output Level LCD Display
•Thermal, Short & Overload Protection Circuitry
•Platinum Plated Screw Type RCA Jacks
•Double Sided Black Epoxy PCB Board
•Platinum Plated Block Terminals
•Fully Unregulated Power Supply
•Stainless Steel Finish Heat sink
•Quiet Fan Cooling System
•Full Mosfet Circuitry
•Frequency Response: 10Hz - 350Hz
•24dB Low Pass Filter: 50Hz - 350Hz
•24dB Subsonic Filter: 15Hz - 50Hz
•Variable 0 - 18dB Bass Boost Control at 45Hz
•RCA Input Sensitivity: 0.2 - 8V
•Low level Input Impedance: 22K Ohms
•Damping Factor: 200 @ 4 Ohm
•2 Ohm Mono Stable
•Dimensions: 12.4” W x 2.71” H x 25.86” D
Kicker ZX1000.1
•ZX Series Class D Monoblock Car Amplifier
•RMS Power Rating:
◦4 ohms: 500 watts x 1 chan.
2 ohms: 1000 watts x 1 chan.
•MOSFET power supply
•LED power and protection indicators
•Tuned Bass EQ (0-18 dB bass boost at 40 Hz)
•Balanced differential inputs make KICKER ZX Amplifiers compatible with any factory radios
•Eliminates unwanted noise in a system
•Boost, gain, and crossover frequencies are top-mounted for easy access, and a handy protection indicator featuring a new flashing yellow low-voltage light enhances the end panel
•Bridgeable operation
•Speaker-level inputs compatible (switchable) through RCA connection
•Preamp RCA outputs
•Automatic turn on modes: remote, DC offset, or signal sense
•Thermal, voltage, and short circuit protection circuitry
•Variable low-pass filter (50-200 Hz, 24 dB/octave)
•Subsonic Filter (24 dB at 25 Hz)
•CEA-2006 compliant amplifier
•Frequency response: 25-200 Hz
•Dimensions: 16-3/4"L x 9-5/8"W x 2-1/8"H
hk4000d - $400 obo + shipping
ZX1000.1 - $200 obo + shipping
Will consider any reasonable offer or trade for competition quality 15" or 18" subwoofer (Fi BTL, DC lvl 4 xl, DD9500, and so on)
HK4000d is newly refurbished to ensure quality
ZX1000.1 is used but in great working order
wink2069
wink2069
Campbellsville, Ky
Exist_ential
