Hisssing noise out of tweeters...
My Power Acoustik Nobium tweeters have the same problem. Maybe they're blown? Not sure, but for reference, mine have built in crossovers.
No, do not bandaid the system. Does the car do it only when running or off or both..? Have you tried different cd's..?? You need to troubleshoot this and find out what is causing it. Try unplugging the rca's and take a regular rca and cut the wires back and deadshort them together, then plug them into the amp and see if the noise goes away.. if it does it is your heatunit or rca's themselves..
i have the same problem, except i can hear my engine through my speakers and there is also a hissing. I have nice streetwire RCA's, and both my amps are grounded to sanded metal...im not sure what else it could be.
I never took care of the problem. I simply mounted the tweeters in place of the rear fill instead of up front. They are a little harsh, so the extra distance softens them, and coincidentally I also can't hear the noise anymore.
I would tell you if the Aiwa set I got off DesertHeat does the same, but I have no crossovers, and there's no chance I'm strapping them onto a 20/20k signal.
I just noticed that while im driving(not idle) theres a high pitched whistle that gets louder and louder as i accelerate, what does this mean? are my gains set too high?
a lil more info-
Pioneer premier deh8-mp head unit
rainbow comps in front
rainbow coaxes in back
arc kar amp pushing the comps and coaxes
For the problem with the tweets, rest assured it's not alt whine. Attached to PC / Xbox, I still get the whine. Attached to home stereo, I get the whine.
Thats a bad ground. I had it when I grounded my amp to metal that was insulated by plastic. Find a part of the car those goes back to the chassis and ground it to that. The seat bolts usually wont work becaus there insulated.
Try that and see if it helps. You could also try a grounding mount.
suprropmp
suprropmp
Los Angeles, California
John3000
