DaveT
I just bought A new water cooling setup and am now hurting for money so my stupidity can be your blessing, gotta let the stuff go I bought it off ebay here is the linky water cooling I would like to get what I paid minus shipping (will ship for free)
includes
* Copper TDX Block for Athlon64 754/939/940 (includes all brass and steel hardware)
* ASUS A8N MAZE4 Chipset Block (includes all brass and steel hardware)
* Eheim 1250 Pump - Quite a powerhouse (includes all hardware for mounting and some bonus rubber vibration bumpers, etc.)
* Black Ice Pro II Radiator /w steel fittings and 2x 120mm fans presoldered and heatshrunk to a single 3 pin connector for a direct hook to your Fanbus controller
* Danger Den Dual 5 1/4" Bay Reservoir - cleaned out properly with the protective adhesive still on the top panel (UV Reactive and also with steel fittings)
* A ton of ClearFlex 60 Tubing 1/2" ID 3/4" OD - Everything in my collection, all fresh (approx. 4'-6')
* More Plastic Snap Tubing Clamps than you will ever need in a lifetime!
* 2x 120mm fans extra. (I think the final connectors have been cut off of one of these 120mm fans so I could solder it to whatever I was soldering it too at the moment but both are new fans)
* Criticool Power Plant AC Relay PCI Card (pre-soldered and connected for the Eheim 1250)
* Tons of extra plumbing fittings and all the factory Eheim pump accessories that came with the Eheim 1250 out of the box.
Additives
* 1 Bottle of Clear Blue Dye-Lite UV Leak Detector Dye
* 1 Bottle of Fluid XP+ Additive
* 1 Bottle of ultra glowing Thermaltake Bigwater Coolant
* 1 Bottle of Danger Den's own Danger Den mct-5 additive
also have a swiftech cpu water block coming that I will let gor for $25 more so we'll call it $225 shipped
prefer paypal but money orders are fine will ship to canada if some shipping costs are compensated
includes
Additives
