hifonics colossus xx ii
nate56
colorado
1. Product:
2. Specs:
“Hybrid” 2-Channel/Mono Block Super D-Class Amplifier
2/1 Channel Operation
Ultra-D Class amplifier Design
RMS power Ratings:
600 watts x 2 chan. @ 4 Ohms
1100 watts x 2 chan. @ 2 Ohms
1600 watts x 2 chan. @ 1 Ohm
2000 watts x 1 chan. @ 4 Ohms
3200 watts x 1 chan. @ 2 Ohms
Illuminated Hifonics Badge
Removable Endcaps
0° - 180º Phase Shift
Variable Subsonic Filter: 15 - 35 Hz
Variable Low Pass Filter: 35 - 250 Hz
Bass Boost: 0 - 18 dB
Bass Remote with Blue LED
Complimentary / Balanced High-Speed MOSFET Output Devices
PWM MOSFET EXVP (Exponential Vari-Power Supply)
SPC Twin Turbo-Torroids with Simpatico Coil Design
Power and Protection LEDs
Gold Plated rca Outputs
Gold Plated rca Line Inputs
XLR Mini DIN Socket for Balance Line Input
Variable input level: 200mV - 9V
2 Gauge Gold power Connectors
External Fuse Required (300A Reconnended)
Power From The Gods Included
Dimensions: 28" L x 11.2" W x 2.6" H
3. Description/Condition:
6/10 looks, 10/10 working
4. Price: :
400
Item Pictures: View attachment 26541116View attachment 26541118View attachment 26541117
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
nate56
nate56
colorado
Jes 42
Decebal
    Jun 10, 2024
