Hifonics Colossus vs. Orion 2500d
Chriscivic
Registered User
Which would you go for to power three dual 2 ohm type r 12's? goign to be wired at 1.33 ohms. the colossus is a little bit more money, but i am more concerned about which will power my subs better. Also does anyone know the fuse rating on the 2500d, the colossus is 300amps. i am leaning on the colossus because it is 2 channel which wwould provide some flexibility if i change subs or something
so you all think 1.33 bridged will be fine on the colossus? right now i have 0 gauge big three, 0 gauge wire for the amp, otherwise just a large battery and a stock honda civic 70. amp alt. thinking of adding a kinetic d2400 in the back for the hifonics or a batcap
you are definatly going to need a HO alt....unless you never turn it up and when you do turn it up its for like 5 min then you turn it off an let your bank of batteries recharge for an hour....
Chriscivic
Registered User
Chriscivic
Upstate,SC
Spkrman
