Hifonics BXI?
Which voice coil configuration do you have on that Type R?
If you have the Dual 2 and the coils are wired in series to a 4 Ohm load then you wouldn't be seeing much wattage out of that HiFonics monoblock.
It would be even more true if you had the Dual 4 Ohm version wired in series to an 8 ohm load - you'd be getting around half of the amp's rated 4 Ohm output.
What coils does your Type R have and in what manner are they wired?
I use the bass knob on my BXi2006d all the time. I'm very picky with sound, but using the knob to adjust the subs volume sounds perfectly fine to me so I'm not sure what everyones *****ing about. Using the bass knob for my application is cleaner than using my HU's sub volume lvl or adjusting it with my epic 150.
Pzaully
vewbvye818
vewbvye818
ny
pzaully
