I have a almost brand new Hifonics Brutus 1700 watt amp. This amp is great has never given me any problems since i've owned it. Amp is only a couple of months old and is still under warranty. Amp will come in box with all the papers. This is the new 2010 model and is built very sturdy and is CEA complient. Runs perfectly at 1/2 ohm ran it a 1/2 ohm daily and worked great never even heated up (only with proper electrical!!) Only getting rid of cause I need more power //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Specs are as follows
RMS Power Rating (@ 14.4V):
4 ohms: 600 watts x 1 chan.
2 ohms: 1200 watts x 1 chan.
1 ohm: 1700 watts x 1 chan.
MOSFET power supply
Wired HFR-3 remote bass level control included
LED power (green) and protect (red) indicators
Variable Bass Boost (0 to +10 dB bass boost at 45 Hz)
Mono channel operation
Preamp RCA outputs to daisy chain multiple amps
4-Way System Protection circuitry (thermal, overload, speaker short and DC protect)
Heavy duty aluminum alloy finned heatsink for maximum heat dissipation
Silver-plated unbalanced RCA level inputs
Silver-plated molded screw terminals
Input sensitivity:
Input Level (Unbalanced): 0.2V-9V
Input Level (Balanced): 0.04V-8V
Variable low-pass filter (35-250 Hz, 24 dB/octave)
Subsonic filter (15-35 Hz, 24 dB/octave)
Phase Shift: 0-180°
Damping factor: >290
Frequency response: 35-250 Hz
CEA-2006 compliant amplifier
Dimensions: 16-15/16"L x 9-1/4"W x 2-7/16"H
Cosmetically 9/10 (Mounting brackets have some scratches from being screwed down)
Mechanically 10/10
Looking to trade for a 3000 watt amp (will add $ if necessary)
$275 obo
Buyer is responsible for shipping
Trades shipping will be discussed
MOSFET power supply
Input sensitivity:
Phase Shift: 0-180°
Mechanically 10/10
$275 obo
