Hifonics Brutus stable below one ohm?
  • 4
brutus is bad enough on voltage at 1 ohm so if you drop it below 1 ohm you better have a very good electrical to back it up or it will fry
So if I keep it above 13 volts will it be good? I have the big 3, duralast platinum, but cant afford a ho alt or a high end amp like a sundown 1500
Yep, but they do rated at 14. Example my aq 2200 was easier on my electrical than the brz 1700 I had
---------- Post added at 12:13 PM ---------- Previous post was at 12:13 PM ----------
Yep, at the amplifiers. I get the same 14.7 volt reading when they cutoff too.
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
I have a Gemeni VII, Heucules VII, Pluto VII, and a Vulcan VII left out of a massive slew of VII and VIII series. They still work Excellent...
  • Locked
COMPLETED Hifonics Plato III
Yes, they are painted. The cover is very easy to take off and repaint to whatever color of choice to match the install.
I recommend wiring to the 2 ohm load on the amp you stated you have, or you can wire to an 8 ohm load for amp stability. You can wire one sub to...
Braindead
Braindead
York, SC
05fronty
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
