500 watts is about all the "clean" power you can expect to receive out of that amp anyhow, but it should be fine for you! The only downside is I think that particular Hifonics amp is Class AB and will probably run hotter than a Class D amp rated to give you 500 watts @ 1 ohm. If a cheap amp is what you are after, then go for it.
