hiding amp in door
azimuth
funded*by*soros
has anyone here ever mount their amp for their comps. inside the door panel?
is there an amp small enough for this?
i was thinking about getting 2 small 2 channel amps and putting 1 inside each door panel to run the front stage. 1 problem i can think of would be grounding points. any input is appreciated. i would also need an amp small enough, yet capable to put out at least 100 rms @ 4 ohms.
my thoughts were to customize the door panel for venting. this is all in the planning stage, but i was also thinking about the kick panels up front next to the floor board. moisture may be some work though in the door panel.
A custom door mount with the amp on the door would be nice...especially some fiberglassing and flushing the amp in the door panel //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i've never done fiberglassing yet. might be a good time to learn. i was thinking about cutting a hole in the door panel the size of the amp and making some kind of cover that matches the panel, yet allows air flow. someone also posted a macintosh in dash amplifier once. for the life of me, i can't find it. i can't remember if it was single din or 1/2 din.
You could totally make that Xtant work - it's not going to prduce much heat at all - you could mount it in a wool sock. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Moisture's an issue but with a good barrier it'd be fine. Running (2) 12 awg plus an RCA thru the door molex - sorry, I'm out of town that weekend. //content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
'glassing a custom mount would be super trick but I bet super tricky too.
azimuth
funded*by*soros
azimuth
Denver, Co
Boulderguy
