HID headlights dancing around :( Help Me
Check all the wire connections. Did it come with a harness to hook up to your battery with separate grounds for each side? If not, there probably isnt enough power running through your stock headlight harness. Otherwise it is most likely the ballasts.
What kind of car is that? If it's a Dodge Ram.... //content.invisioncic.com/y282845/emoticons/hide.gif.2d479cfd917eedfe201353b91522ceab.gif
Damn! i think it could possibly be both ballast //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
because i hooked up a capacitor...nothing
switch over to a relay.....nothing
and finally i just plain hooked it up to a battery..... Its still flickering //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
1997 Montedaytime running lights
Manual switch on dash
9005 Bulbs
But im not sure if saying this will help any... since i connected it directly to the battery
That's the first thing I was going to guess. You have to deactivate the DRLs, as they send less voltage to the headlights. For normal halogen this is fine, but not for HIDs.
Just was on MyMonte.com
and no one else there has had this problem,
i really think its just the ballasts.... ill see what happens though, i contacted the seller
TMali
I Can Dance If I Want To
TMali
New Hope/Big Lake MN
TMali
