This amp is in real good condition, only issue is the scratch seen in the pic, other than that its 100%.
Looking for $225 shipped.
Thanks for looking
The EP 4 is an amplifier designed to reproduce any musical genres: thanks to its four separate channels, it provides many different system configurations. Pre-amplified inputs as well as hi-level inputs offer the possibility for the EP 4 to be interfaced with any head units, including factory OEM sources. EP 4 boasts extreme reliability thanks to the use of FR-4 double layer PCB material. 70µm thick copper traces in combination with robust copper bars are used for paths with high current transfer. The B channels feature Bass Boost adjustable within a range of 0 ÷ 12 dB at 45 Hz to offer a deep, solid bass with control. Advanced electronics and optimized cooling system allow the EP 4 to provide high power, even under difficult conditions.
# 4 x 60W 4Ω
# 4 x 95W 2Ω
# 2 x 60W 4Ω + 1 x 190W 4Ω
# 2 x 95W 2Ω + 1 x 190W 4Ω
# 2 x 190W 4Ω
Thanks for looking
# 4 x 60W 4Ω
# 4 x 95W 2Ω
# 2 x 190W 4Ω
