Sold hempy's FS thread: tc12 oem, css sdx15, boxes, amps, ht spkrs
hempy
bass wiener
I'll be adding things/pictures/updating information as I go along.
First up is my TC Sounds Oem 12. I bought this from 97grnissan back in Oct '07. It's been used lightly in a home theater run with about 750w. It's in great condition except for some scratches on the basket near the terminals from a mounting issue. You can see them in the pics near the terminals.
$180 shipped
Next up is a CSS SDX15. I bought this in Dec '07 from CSS. I had it in my Jeep running on about 1000w. It sounds amazing, but has some cosmetic issues. First off, the backplate has developed some surface rust, apparently due to our high humidity. It's really thin, and will probably clean up with some WD40, but I haven't messed with it yet. The pole vent doesn't have rust, and there's definitely no noise from the sub. Next is the mounting holes. When I got the sub, there was a lot of excess glue from the surround in the mounting holes. I cleaned them up, but it wound up scraping off some of the powdercoat in the holes. Third, the back of the mounting flange is a bit of a mess. I used some rubbery speaker sealing stuff from PartsExpress and it wound up being a ***** to get off. It really sealed it well, but it just looks a little messy. I'll keep trying to get the rest off in the meantime. I have pics of everything below.
$200 + shipping
Next is the box that housed the SDX15. I have a build thread for it here, but I'll try to briefly explain everything about it here.
It's around 4 cubic feet, tuned to 25hz. The two 4" Precision Ports are removable, and they can be dismantled and rebuilt to change tuning as well. The box has a double baffle, and three rib braces inside. The inside of the box is lined as per the instructions from Creative Sound (for the SDX15). I have t-nuts installed for the sub, although it may not fit all 15's. The SDX uses a JBL-style basket.
I used a rubbery sealer with the ports (same stuff on the SDX15 and it stuck so well that when I took out the ports for the first time, it took a thin layer of mdf from the port mount. It can easily just be filled with the same stuff or something less adhesive. I may repaint it to get rid of the mdf color.
The back of the enclosure is an incorporated amp rack, with inlets for cables (2 available, one is cut out and installed), 6 fans, each wired to run at 6v (compromise between loudness and airflow) to circulate airflow (3 in / 3 out). There are two smoked plexiglass windows for the amps I was using, the left one is 14" x 6.5" and the right one is 8" x 6.5". The exterior dimensions are 42" x 18.5" x 17.5".
The front face of the enclosure is black countertop laminate, while the rest of the box is wrapped in grey vinyl. The trim piece around the front face is screwed in from inside the box. While uninstalling the box, I managed to catch the vinyl on the top on something sharp and it left a small tear, about 1/4" in size. I have closeups pictured, and I'm trying to find a way to make it less noticeable...I thought I remember some infomercial having stuff to fix vinyl tears, but I dunno.
The back of the amp rack is held on with six bolts that bolt through the back of the enclosure. This essentially makes on-the-fly tuning impossible, but as long as you set up/tune everything before closing everything up for the last time, it makes for a very nice and clean installation.
$300 OBO (no clue about shipping)
I also have some other stuff to put up once I get pictures of everything.
2x Vifa PL27TG-35-06 tweeters
2x Vifa P17WJ-00 woofers
This HT sub enclosure
DX1000.1 & DX200.2
I am also selling a pair of Vifa PL27TG-35-06 tweeters and a pair of Vifa P17WJ-00 woofers. I bought these back in February of '07 from PartsExpress. I used them occasionally in a 2-way setup for about a year. They are all in great condition. The backside of one of the tweeters has some residue from a foam tape that I was trying to use to seal the box; I'm going to clean it off once I get the chance.
$75 + shipping
$55 + shipping
I was wondering about these subs. What do they compare to? Is it strictly a sq sub,, or does it get loud? Any trades on it. I want to experience an xbl sub at least once
I would definitely say that it's geared for sound quality, which in this case accounts for a very nice low end. The fs is 19hz and I ported mine low (25hz), so in my application I gave up some output for low-end extension. It all depends on the install.
That being said, I think most 15" 1000rms subs could be considered "loud".
Will tak offers on everything. Got arrested and need cash. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
hempy
bass wiener
hempy
nola
hempy
