help
  • 4
jb2xx
I love asian babes!!
Seems that the 40A fuse that is in the fuse block going to my kx400.1 amp is getting melted from the top end that is coming from the battery. Nothing happens on the output end going to amp. Seems that solder that is within the casing of the fuse is being melted & drips out.
I have been through 3 fuses already. Fuse for the kenwood for mids/highs amp is ok. Nothing happens with that.
Anybody knows what I can do to remedy this? I have Rockford fosgate wiring 4 guage. Everything is 4 guage except for fuse block to kenwood amp...that is 8 guage.
Would it be ok to just run the wire from distro block to kx400.1 amp w/o fusing considering that the 4 guage is already being fused at 60A next to the battery?
Fuse is to protect the wire right? So it would mean for exception of the kenwood amp, all 4guage wiring is fused at 60A. Kenwood amp is fused from distro block at 30A.
Please help!
melting from the top??
the fuse or the casing?
try putting a 80a agl by the battery ans dual 60 or 80 at the distro block..you MIGHT be tryin to pull more then you can get..idk
melting from the top??the fuse or the casing?
Thanks for the tip. I will try that.
You may need a digital LOC that has a bass restore feature. Audiocontrol LC2i Pro is one such device.
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
109
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
248
jb2xx
jb2xx
Los Angeles, CA
themainjam
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
