Help!
  • 2
drummer_punk82
Michigan
Ok, here's the stuff I got:
Sony Xplod 150W RMS @ 4ohms(stereo) OR 380W RMS @ 4ohms(mono)
2X JL Audio subs W3 10" @ 4ohms & 250W RMS
Yes, I do know that my amp isn't the greatest for the type of subs I got, but I didn't have much $$$ and really wanted to get some bass going.
Now, I was wondering if I could bridge both subs to the amp. Meaning put both of the "+" wires in the "+" terminal and both of the "-" in the "-" terminal without blowing anything up. Would the ohms be mismatched and eventually blow the amp?
If the 10w3s are dual 4 ohm, and you hook both the voice coils and speakers to the amp in paralell, your amp will see a 1 ohm load, more like .8 ohms. You should not do this unless your amp is stable at 1 ohm mono. Some of the sony es amps are. check the owners manal.
If the 10w3s are dual 4 ohm, and you hook both the voice coils and speakers to the amp in paralell, your amp will see a 1 ohm load, more like .8 ohms. You should not do this unless your amp is stable at 1 ohm mono. check the owners manal.
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
184
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
202
11
444
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
6
274
drummer_punk82
drummer_punk82
Michigan
indosia
just call me KeV
    Apr 27, 2024
just call me KeV
    Apr 27, 2024
Latest topics
