Help with passing speaker wire through door jamb
hondarider
How do you get the speaker wire through the door jamb? I can pull the rubber boot piece out of the door when it's open and send a wire into it but i can't find where it comes out. I can't find the hole on the inside of the car. Any help is appreciated.
this shouldn't be that hard... you have a hole where the wire goes in, it comes out on the other side. it might just be blocked by other wires.
edit: poke around with your finger. or turn off the lights and shine a flashlight through one end of the hole, then look for the light.
Drill a hole in the door, and use a grommet. The second part of that is more important than the first part. You *will* shear a wire without one.
236
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
257
497
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
305
hondarider
hondarider
glidden, IA
Raven
slater
    May 2, 2024
slater
    May 2, 2024
