Help With Alpine Gain!
SoCaL081
50
Hey everyone I recently got a Alpine mrp-m500 amp to match and power my 12" Eclipse SW8122DVC sub but anyways...i was setting the gain to the amp while using a multimeter trying to reach rhe 31.6v for 500w rms @ 2ohms and it would read low ac volts maxed out and only got to the number by turning up the bass eq up quite a bit. My headunit has 4v preouts and the alpine amp has a max of 4v so do i just max out the gain?
You need the sub volume control maxed out at +15 and volume at 33/35 which is the max level before clipping in order to be near 4v.  Gain shouldn't be turned up that much 1/3 at the most I would think.
as stated in the post before mine, when your deck volume is almost maxed out is only when itll produce 4v output, and if your amp has a max of 4v in, then your gain should be down pretty low if you turn your deck volumes up that high on the regular. it is dependent on where the highest number you ever turn your volume to is
SoCaL081
SoCaL081
SoCaL081
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
