Help with 1.33ohm Amp Math Twisted Sounds 3.5 DC Audio 15"
  • 2
Shelbywh89
Hello, Guys
Looking at running Three DC audio Level 4 15's Dual 2ohm wired to a 1.33ohm load
Using a Twisted sounds 3.5
Question about figuring out the Watt the amp will push
Birthsheet says
2ohm 2546 Watts
1ohm 4789 Watts
4789 - 2546 = 2243/3 = 747.6 per .3333ohm
so 1495 for the .66ohm we keep 2546 + 1495 = 4041 Watts
SO would the total wattage for a 1.33ohm load be 4041?
Does this setup sounds okay? running each sub at 1350RMS is the numbers are right. Amps uncertified 1ohm was just above 5k so hope it will be okay.
Thanks you
319
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
297
539
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
346
Shelbywh89
Shelbywh89
Seattle,WA
Shelbywh89
Brendon Jenness
    May 8, 2024
    May 8, 2024
