help me please
2003 HONDA ACCORD TIPS
1) How to reset the Maintenance Required Light
-All you do for this is press and hold down the odometer reset button
-Turn the key to Start (But don't start the car)
-Keep holding the odometer button until the Maintenance Req'd Light stops blinking.
-Turn the key back and remove
-Let go of the Reset button
-Turn the key all the way and it should be gone.
2) How to remove the Factory Stereo
I had to pull out the stereo because my Son and God-Daughter put coins through the CD player.. LOL.. Kids will be Kids
-Remove the Trim around the shifter
-This will expose two screws under the coin tray and cigarette lighter
-Pray off of the Shifter Lock Bypass thing. Press your key through and you should be able to shift it down into Gear
-Pray off the Coin tray part. There are two screws under that.
-Now the Coin tray and the Cigarette lighter comes off.
-There are two screws that hold down the lower compartment
-Pull the Lower compartment off.
-There are two screws underneath that hold the Stereo, remove those.
-Now pry off the top center Dash. (Carefully use a flat head and pry closest to the upper part of the stereo) There are only 4 plastic tab locking things that hold the top Center Dash.
-That will expose the two screws that hold the upper part of the stereo.
-Disconnect all the cables and the factory stereo
Click here for the replacement Stereo Harness at the Factory Stereo Location
**Remove your Factory Stereo at your own Risk! I will not be liable for any damage or injuries to yourself or vehicle**
gd hope u didnt write all that i thin he is looking for this ..
2003 Honda Accord Wire Layout
FUNCTION..............WIRE COLOR..............POLARITY..............LOCATION
12volts..............white..............+..............ignition harness
Starter..............black/white..............+..............ignition harness
Ignition..............black/yellow..............+..............ignition harness
Accessory..............black/red..............+..............ignition harness
Second Accessory..............white/red..............+..............ignition harness
Keysense..............red/white or red/black..............-..............ignition harness
Power Lock .... pink/black .... - .... grn plug, L side of fusebox
Power Unlock .... pink/blue .... - .... grn plug, L side of fusebox
**These wires will meter while using the passenger door lock switch.
Lock Motor .... yellow/black .... 5wi .... grn plug, front of fusebox
Unlock Motor .... yellow/green .... 5wi .... grn plug, front of fusebox
Disarm Defeat .... yellow .... 5wi .... large wht plug above fusebox
Parking Lights+ .... red/black .... + .... large wht plug above fusebox
Parking Lights- .... black/red or blue/red .... - .... in steering column cover
Hazards .... green/red .... + .... large wht plug above fusebox
Turn Signal(L) .... red/blue .... + .... large wht plug above fusebox
Turn Signal® .... brown .... + .... large wht plug above fusebox
Door Trigger .... green/red .... - .... grn 5 pin plug behind fusebox
Trunk/Hatch Pin .... blue/black .... - .... driver kick, harness to rear
Hood Pin .... yellow/red .... - .... hood pin switch in latch
Trunk/Hatch Release .... yellow/green .... + ..... driver kick, harness to rear
Factory Alarm Arm .... white/red .... - .... driver door module in door
Factory Alarm Disarm .... white .... - .... driver door module in door
Disarm No Unlock factory alarm disarm
Tachometer .... blue/red or blue .... AC .... ECM/PCM
**The ECM/PCM is on the front of the transmission tunnel.
**The connectors are on the passenger side.
**On the 4 cylinder models the tach wire is in the white 31 pin connector E, pin 25.
**On the 6 cylinder models it is in the gray connector A, pin 23.
Horn Trigger .... green/yellow .... - .... steering column
Speed Sense .... blue/white .... ECM/PCM
**On the 4 cylinder models the VSS wire is in the white 31 pin connector E, pin 26.
**On the 6 cylinder models it is in the gray connector A, pin 11
Wipers .... blue (L), yellow (H) .... - .... windshield wiper motor
LF Window up/dn .... red/black - red/yellow .... LF window switch in door
RF Window up/dn .... red/blue - red .... RF window switch in door
LR Window up/dn .... red/white - blue/black .... LR window switch in door
RR Window up/dn .... red/white - blue/black .... RR window switch in door
Sun Roof open/close .... green/yellow - green/black .... moonroof motor, rear of roof
**Only on the sedans.
**Coupes: the moonroof motor is integrated into the moonroof control unit not allowing
**access to the motor wires.
Radio 12v .... white/green .... + .... radio harness
Radio Ground .... black .... - .... radio harness
Radio Ignition .... yellow/red + .... radio harness
Radio Illumination .... red/black .... + .... radio harness
Power Antenna .... yellow/green .... + .... radio harness
LF Speaker +/- .... green/black - lt. green .... radio harness
RF Speaker +/- .... grn/yel - gray or gray/red .... radio harness
LR Speaker +/- .... blue/white - blue/black .... radio harness
RR Speaker +/- .... pink - blue/yellow .... radio harness
fatboyracing
fatboyracing
Owensboro KY
fatboyracing
