Help me out please AMP questions
ArcFault
they are single 4 ohm mtx 300 rms subs they will take 500 easily tho. a gpv 2000.1 would be quite a bit stronger at 2 ohms than the 1400.2. you can also get much better subs cheaper even to canada //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif i ship to canada alot it is about 30$ extra is all.
I already have the subs. I was told to run them at 4 ohms.. I was alaos told the only way to run them at 4 ohms was to put each one in it's own channel. Has something to do with the style of music I listen to.
Why would this amp only deliver 200 each?
here arethe specs.
Mfr. Part Number: TC512
Band Pass Volume Not Applicable
Basket Material Stamped Steel
Binding Posts Chrome Push Terminals
Cone Material Expanded Poly
Frequency Response 30Hz - 150Hz
Impedance 4 Ohms
Magnet Weight 1.98 kg
Mounting Depth 6 11/16"
Ported Box Volume 2 ft/3
Power Handling Max 900 Watts
Power Handling Nominal 300 Watts
Product Warranty 1 Year Parts & Labour
Recommended For Band Pass No
Recommended For Ported Yes
Recommended For Sealed Yes
Sealed Box Volume 1.25 ft/3
Sensitivity Not Applicable
Surround Material Rubber
Voice Coil Size 1.75"
Woofer Size 10"
if these are single 4's,how come in your other thread you said you need 4 ohms?are you not bridging the amp for more power or are you running 2, 4 ohm channels?
if you bridge,you need 2 ohms,right?
if these are single 4's,how come in your other thread you said you need 4 ohms?are you not bridging the amp for more power or are you running 2, 4 ohm channels?if you bridge,you need 2 ohms,right?
I don't know... I was tod to run two 4ohm channels... I have no idea how to select the ohms I want to use. And yes, I want to run them at 4 ohms. And I don't understand that bridging stuff.
I understand you use positive on one and negative on other. From what I understant I wont get 4ohms that way.
I think.
ArcFault
ArcFault
Canada
ArcFault
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
