I'm trying help my friend install his system...
It starts with Memphis 4g wirng coming from the battery to a 2 fared Memphis Digital Cap. Cap is grounded secure. Two 4g wires coming from the cap. Each lead going to a Memphis Power Referance 1000.1. Two grounds coming from the cap, each connected to the amp. The amps connected to a 12W7. The Rca's are coming from a Alpine CDA-9856 headunit. then a set from one amp to the other amp..
All connections are solid and secure.
When you cut the system on.. it'll stay on for 5-10 seconds, then one amp always goes into proteciton. We messed around with it for about an hour, then it got dark on us. Am I missing something.. should I run a seperate set of RCA's on his headunit.. im out of ideas.. any can help?
