Hell of a Situation.
Well, I'm kind of confused as to whether they sound good together at lower volumes or not. If they don't sound good even at low volumes, one has got to be out of phase. Did you try switching one just for shits? If that's not it, then their might be some sort of weird cancelation going on inside that box.
their not wired out of phase i took them out and wired them two times and then after that we took one subn out and left one in and plug the mounting hole and it was louder than the two in i dunno its really confusing and wierd
Try flipping the phase switch on one of the amps? Sounds like they are outta phase, I did that with a couple tens I had a while ago, almost like no bass at all, they just shake around a little bit and sound shittttyyy.
Since it is 1 amp per sub, my best guess is that something funky is going on inside the box. Maybe try hooking up the 2 subs to just 1 amp and see if it makes a difference, just try different stuff //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
they sound good together at low volumes...but onces it gets to a point (volume 15 or so) they kinda cut out and just flex, but make real shitty noise.
but then if you take one out and just play one in that box its loud as hell:naughty:
switch the + and - on one sub... very simple.
You absolutely have to be wired out of phase.
Its also possible that the phase on the amps is set differently... would probably be the first thing to check.
phase on the amp, now go fix it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
HotCarl
The Cleveland Steamer.
HotCarl
Northern Illinois
justsayk
Mike Mccabe
