my2006c6
Hey guys... Was going to grab one of these up, from woofersetc for 249.99 free ship and New..
I was on the amp's home page, and it seems this may be the older unit of whats avalable now.. - But wonder if it really puts out what it says..???? - Was thinking of getting it to replace my boston acoustic, GT-42.4 that i use ch 1+2 front compo,- channel 3+4 to run my SVC, 4 ohm sub. And thought this may be better. ???? Thoughts ???
Here's the specs on the helix
Cont. power rating RMS/Max. power at 4 Ohms/13,8V: 4 x 75 + 1 x 350 Watt
Cont. power rating RMS/Max. power at 2 Ohms/13,8V: 4 x 110 + 1 x 550 Watt
Cont. power rating RMS/Max. power at 4 Ohms/13,8V bridged: 2 x 220 + 1 x 700 Watt (1 Ohm Woofer)
TIM distortion:
Signal to noise ratio: > 93 dB
Bassboost : 0-18 dB
Setting range highpass : 10 Hz-2,5 kHz
Setting range lowpass : 40 Hz-4 kHz
Regelbereich Bandpass : 15 Hz-4 kHz
Setting range bandpass: 10 Hz-30 kHz
TIM distortion:
Signal to noise ratio: 200 mV - 5 V
Fuse: 1 x 100 A
Input impedance: 10 kOhm
Dimensions (HxWxD) mm: 64 x 282 x 570
TIM distortion:
Bassboost : 0-18 dB
TIM distortion:
Fuse: 1 x 100 A
