1. Remove the black shield that covers the headlight area (not all models are equiped with this but you will know if you have it) it uses fastners so you just need to remove them.
2. locate to the clips on the headlight you will see a little thing like a tab you want to pull those 2 clips up you may have to use a flathead screw driver because their is a notch that is sometimes hard to make the clips pull up
3. after pulling the 2 clips out the headlight will come out.
4. then you want to twist the bulb assembly counter clockwize one sixth of a turn and pull it off
its hard the first time but easier after that.. I remember when I had to change the light bulbs in my auntys grand am.. heh.. it was a pain but anyways, Goodluck //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
