No low beam headlight operation, no Daytime Running Lights (DRL) operation. Vehicle owner replaced the headlight switch and the multi-function switch on the column. Tested all fuses. Have power at headlights, no ground. Can ground light at headlight and lights do work. Tested at headlamp ground relay. Has ground at Black wire. Light Green/Black wire is not grounded. High beam lights are on normal operation. Ground the Light Green/Black wire, the high beam lights decrease to half brightness.
Tests/Procedures: 1. Test Yellow wire from ground relay at body relay block terminal A11 to C211 48 cavity connector below steering column terminal E13.
Potential Causes: Ground
Terminal Contact
Wiring
Tech Tips: Body relay block is located behind left side of dash, right of the Instrument Panel fuse block. BROKEN WIRE ON CURCUIT 525 INSTALLED NEW WIRE FROM MULTIFUNCTION SWITCH TO HEADLIGHT.
