Head Unit won't detect flash drive?
Hey, I've recently purchased and installed a new Pioneer AVH-X1700S unit.
I ripped about 20 CD's on my laptop and transfered them to a new blank 8gb flash drive.
When I plug the fash drive into the USB extension that comes from my head unit, it doesn't detect it or do anything.
Is this a format issue? Do I need a different or special type of flash drive? Can someone please advise me here, thank you.
Do u know of ur hu uses nfts or fat32 filing system, u will need it formatted to the proper filing system with ur pc
Honestly I'm unaware of the recommended or required format my head unit prefers. I read a good amount of the manual but haven't came accross anything helpful. Is there a way I can check what the current format of the flash drive is by plugging it into my laptop? Because if I know what format it's currently in, I can format it to the opposite and try again to see if the head unit will detect it.
Are they drm protected? And it says it can play wma, try to format to ntfs
Make sure u have ur music still on ur computer before u format
I format mine fat32 no issues. I have used wav, MP3 and other formats in my AVH-X5500BHS. Sure your plugged into the back with the wire and it didn't come loose? I can hit USB on the menu if I' am switching boots right up.
SoulSoak
SoulSoak
Holland, Michigan
negolien
