Head unit wiring help
beckSHO
Okay, so I have recently installed my 6800mp in my Taurus. Because of the electronic climate controls, I can't do a dash kit and be done with it. So, I decided to fiberglass it into the center console, in front of the shifter. Now, I am just about done. Still have some bondo-ing and painting to be done. Now, all I need to do is wire it up. In order for my deck to work properly, all I need to hook up is the constant power, switched power, and ground, right? Now, I have no idea where to find those wires. I have searched and found nothing to help me. The vehicle is a 97 Taurus SHO if it helps any. Hopefully you guys can send me in the right direction. I looked at the wiring harness for the non ECC Taurus, but I think they only give you speaker leads, not the power. I'd appreciate some help here guys, and I'll get some pictures up as soon as it's done. Thanks.
Wow, no replies....
Okay, how about this... Will my deck work if I have a constant power, switched power, and ground hooked up? Are those the only connections I need?
beckSHO
beckSHO
Michigan
beckSHO
