Head unit randomly turns off/on (Toyota)
  • Thread starter blaze_01
  • Replies 0
  • Views 563
blaze_01
Hello.
Ok, first, its a Toyota Avensis (EU name)
For USA i dont know what its called or even available, but heres some related
information from wikipedia:
Also called Toyota Corona T220 (Greece)
Predecessor:
Toyota Carina E (Europe)
Toyota Vista (Japan)
Production 1997–2003
I think the avensis replaced the camry
It has a Stock "toyota" headunit which have stopped working.
Its completly black, no power at all. But it sometimes turns on, stays on for a while, then goes off again.
I took it out to look at cables but to find nothing weird.
I decided to replace the unit with my own WORKING unit, which also DIDNT work in the toyota.
Also black screen, no power.
After some driving it just poppen on, and i played some music for 15 minutes before it goes black again.
after taking the unit out it was also quite overheated, i did however play a bit loud. (no external amplifiers)
The headunit always turns on for a brief moment making a beep sound at the same time as i stop the car (ignition off) like some kind of "good bye" sound when turning off the vehicle.
But the unit rarely starts when i start the car.
So i bought a new set of cables to replace and checked that every cable was right fitted which i am almost 100% sure about.
Now i did some measurements with my voltmeter.
here is what i found out:
With Head unit taken out
The ignition cable (RED) + Ground = 13 volts
The Battery cable (YELLOW) + Ground = 13 volts.
With cables/socket mounted into headunit (tried both units)
The Battery cable (YELLOW) + Ground = 1,2 volts.
So with the cables in the unit, i drop 11 volts on the battery cable.
As soon as i take the cables out, i get the volts back.
I know my own headunit is working, the toyota unit has also several times turned on.
Please, any suggestions? where can i go from here to figure stuff out?
blaze_01
blaze_01
Norway
blaze_01
