Head Unit Problems
if you didn't disconnect the battery when you started the install, then you could have blown a fuse. check the fuses first.
did you use a wiring harness adapter (like from Metra)? how did you make connections (tape, solder, crimp)? a DMM can certainly help you verify you have +12V constant and ignition.
I haven't had time to really take my time with it. I did use crimps. It has an external fuse checked it, and thats ok. I bought the install kit and it had the wiring harness in it for her escort. Thanks for the input. I will check for power monday.
audiobahngods
audiobahngods
Clover, S.C.
1rockford1
vegang
vegang
