Head Unit Powers On = Lights Dim
xstatic26x
Hey everyone, this is a new problem and I'm wondering why it's happening to me. I recently switched my amp for an Audiobahn to an MTX, using the same wiring (wiring is adequate gauge). I reconnected everything to the amp correctly, the same way I had the Audiobahn one wired up.
Anyway, as soon as my head unit turns on (when I put a cd in or something), the amp powers on right away, or within a second -- like its supposed to. However, right when the amp powers on the lights dim real bad for a second, whether I'm at idle or driving. The lights don't even dim when I have the bass thumpin', so its not my alt size I don't think, and this didn't happen with the other amp.
Any ideas? It's not really affecting anything it's just annoying me
If that the worst of your problems your doing alright.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
mine and a friend of mines mtx 801d's used to do that. a buddy of mine has 3 of them...lights basically go out and he has a ho alt, big 3, and an extra bat ( i believe he even has 2 extra's now)
they dim bad...maybe it's mtx???
i know it has something to do w/ the remote...it pulls too much current from the remote source or something...thats what some "professional installer" told me
Anything wrong w/ the amp doing that, don't want any damage or anything to occur, but what you said makes sense to me.
too much current being pulled through the remote wire = no HU. Get a relay. PE has one with a diode in the socket pretty cheap.
Ok, I'm new to this stuff...can you tell me what PE is and what a relay w/ a diode is too?
Thanks
PE is http://www.parts-express.com they sell bosch relays and sockets. That'll let you wire true 12v power for remote wires and have the HU, or switch, turn it off and on for you. A relay uses a low voltage signal to switch higher voltage. Your car already has a few. Example- HEADLIGHTS, you don't REALLY have the 12v line for your headlights running through the switch. That signal trips a relay that does the heavy work for you. Go give http://www.bcae1.com a read too, plenty of good info with demos and graphs and stuff. Another source for audio info is http://www.the12volt.com/
xstatic26x
xstatic26x
Belchertown, MA
xstatic26x
