head room - how much = too much?
brian84corvette
hey all.
im pondering ideas about what amp range ( rms watts )
to move up to.
this time tho, I believe I want a little more headroom than now.
as I have bxi1206d - and its a great amp and all,
but its probly only giving off a hair over 1K rms.
my sub is re sx 18.
in a ported box 5.4 cubes after port and sub disp.
so basicly im feeding the sub exactly what it states it can take.
but I have a sneeking suspicion that it can actually take more.
id feel comftorble giving it 1500w ?
on a side note to this topic - I am purchacing upgraded alternator tomorrow
so electrical will not be an issue, having 120+ amps at idle / 220amp full tilt.
so I doubt I could possibly drop below 13.5v anymore once installed.
that being said - power should be nice and clean ( I hope at least )
so that means I can send more power to sub right?
is 1500w on my re sx 18 too much ?
is 1800w too much ?
what do yall think?
I had the RE HC (older model SX) and I gave it 1500wrms and it took it no problems. The good thing about having a larger than needed amp is you can always just turn the gain down. Just because you have a 2000wrms amp doesn't mean you have to use all of its power. So go big if you know you'll be upgrading later on
your gonna have too much headroom with that 18" //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
haha - actually in my little *** car -
the 18" and amps leave hardly any extra room.
need to have windows down to fully "bump"
hahaha. - I should experement with the top off also.
should be able to hear it coming up for blocks like that.......\
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
hey all.im pondering ideas about what amp range ( rms watts )
to move up to.
my sub is re sx 18.
is 1800w too much ?
what do yall think?
"Headroom" is power that is never used, by definition. So, you are not looking to gain headroom, just usable power, the opposite of headroom really.
The answer to how much headroom is too much... when your wallet says no more, or your sanity creeps in and tells you that you are well beyond the point of diminishing returns. Otherwise, there is no ceiling for headroom. But the answer to your question is, when the coil starts getting stinky. That's when you back the gains off, and call it headroom.
I like that...well said
brian84corvette
brian84corvette
coral springs FL.
nauc
