dang, i'm in the market for some comps and possibly a battery, we'll see how bad i dim after i do the big three. don't really need any boxes as i build my own. the Q was retired because i missed having some spare room in my back seat so i replaced it with the stuff thats in my sig. but i miss the output so its going back in with a smaller box and a different amp (zx1000.1).i've got a 9518g motor/basket, and an optima yellow top g31 i'd sell ya cheap. still have that alumapro alc 6.2 component set too. i also have a couple of bj fisher built, pete kulicki designed ported boxed taking up space in my garage... one for an 05 xxx 18 designed for flat response, another for the 9518 designed to get piss loud, both 41 inches wide. what happened to the q 15 i sold you?
let me know if you're gonna be in wichita and want to have a listen to it sometime.
Haha, that makes no sense really. Could we have fit in under? Sure.You aren't intelligent enough to make it do both? I feel for you.
i dont think them being agm has anything to do with the voltage they can handle. there are 16v agm batteries. mine are 12v batteries, and 14.4 would be the normal charge for them. i know when i would start my truck on a really cold morning, i would show low to mid 15s before i had the mla module, the other day when it was 20 or 25 degrees i was showing 15.8/9 with the mla installed. normally, its at 15-15.5 when the weather is more reasonable. i know there are a lot of people running mla modules at 15.3 with 12v batteries with no issues, so i'm not worried about it.Looks good, a friend of mine has the same subs on a AQ 2200D and they hit really hard. Let me know how that MLA module works out, I am considering one for my van. Can you regulate the voltage with those modules?, I thought you are not supposed to run more then 14.5 volts into a AGM battery.
