Having some BIG trouble...
just take it to a mechanic
when I worked at a parts store people would spend like 200 bucks trying to figure it out and still take it to the shop
or
you could pay say 100 for them to look at it and tell you what is wrong
if you think you can fix it do it,if not let them do it
This started today... i was driving my car then all of a suddon it just shut off on me. i put the car in neutral, started it up and drove again, few mins later it died again. No clue what the problem could be?!?! any ideas?
crank sensor most likely.
it gets hot and heatsoaked and the sensor goes "open" (ie open circuit) because the metals expand inside when they get hot. it cools down a bit, metals condense a bit and the sensor works like it should and the car will start up, just to get the crank sensor warm again and "open" and the car dies.
you have a pretty "textbook" case.
go to autozone, pick up their tester, go through and find the crank sensor info (or just find engine speed) let the car idle until it dies, then quickly try to restart the car and watch the engine speed on the tester. if it reads 000 while the engine is cranking, you need a crank sensor.
Adrian15XXX
Adrian15XXX
Chicago, IL
lincolntc690
