Hair Trick?
swoosh
monkey lover
Hmmm, I've been wondering about this for awhile... What is the minimum you need to pull a hair trick, dB wise? Or is it not based on the loudness but how much air is being moved? Also, what is the most compact, smallest system you have ever seen pull a hair trick
Thanks,
Anthony
Thanks,
Anthony
its how much ai is being moved. i saw a video i thin it was an s10 or some small truck with 2 15" l7's with 1000rms each ported in mid 40's. and of causre there are some w7's videos with the hair trick
just look on realmofexcurtion.com you will see quite a few videos with the "hair trick"
Children.
There is no SETUP or anything that will gaurantee a hair trick //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
NG
i bet if u put the port blowing out the window u would do a hair trick..//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Looks like a nice system! Sound good? How are you liking the Xenon amps?
Sounds great. Loud as hell, and the xenon amp looks great, and sounds even better. Definately the loudest system in my area, or that ive ever heard as a daily setup. The lows on these subs will have your ears hurting. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
wow, so basicly you want to build the cheapest possable system but be able to mess peoples hair up that are in your car.. thats your soul purpos.. not to sound good but move poeples hair... man this should be FUN!
Denial, I never said that. I was just curious about what the smallest system to pull a hair trick was. I never said anything about cheap, or that I was trying to put together a system just for that purpose. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Anthony
yeah, its about air movement. inhumanack and i were doin a 154.5 and it couldnt blow your hair around...
Thanks for the input //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
I got the answers I needed
Anthony //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
swoosh
monkey lover
swoosh
Glendive, MT
swoosh
NorthFramingham
    Jun 30, 2026
