Ground question
the fuqq you jus say
Let me try saying it again. I want to take my battery's negative terminal connect some wire to it, with the already existing ground for the battery hooked up. Use that wire I hook up to it as the ground also for my amp. Is that possible or not?
Grounding your amp to your battery is the best one you can do IIRC.
Well the only sources in the vehicle are the battery and the alternator so grounding to the chassis is simply a round-about way of grounding to those. If the battery is close, ground straight to the terminal, I would consider that optimal provided that battery has a good ground connection to the alternator.
murph
Low for Life
murph
Richmond,VA
bubbagumper6
vegang
vegang
