Gronding at engine block?
All_Logix
Formerly CivicGTi
So have been dealing with engine whine issues for a while so I had this idea...run 4 AWG from where I grounded the engine block to the chassis for the big 3, run it to the trunk and strap a distro block to it to attach to all of my amps.....then I will run a wire from my HU ground and ground it at the engine block as well... any thoughts on my brilliant grounding idea
the engine whine is usually voltage drop related - and from grounding point selections or connection resistance.
the vehicle metal should have lower resistance/ft. than 4 awg wire. it's worth a try, but i'd use 1/0. i'd ground HU to amps first - that is the crucial ground loop circuit you want to minimize. your plan introduces more resistance between amp and HU.
sometimes, it's just the amps or HU causing the problem.
All_Logix
Formerly CivicGTi
All_Logix
Texas
keep_hope_alive
