graphic or parametric
If you have a lot of bands graphic is easier and it will give you almost all the control you'll need to correctly tailor the sound. With less bands, maybe 5-7, parametric would be better. You don't have as wide of control with less bands and if you have certain frequencies that need to be tailored in any way, one of the bands will more than likely be able to adjust to that frequency to take care of it.
Or if you're like me my Eclipse HU has 10 bands parametric and I have an AudioControl DQS for 30 more bands, graphic, per channel + 2 more parametrics per channel. It's b!tch to tune, but well worth it.
One isn't better than the other.
Parametric gives you more control due to being able to select specific frequencies and target specific problem areas. More flexibility in control due to adjustable center frequencies and adjustable Q.
Graphic typically has more bands for broader control, but since center frequencies and Q factors are fixed so you have less precise control. What frequencies you can adjust and the Q of the filter is fixed, so you are limited to what the graphic EQ offers.
A lot of people prefer a good parametric due to the flexibility, even though it offers less bands.
Seems like your last 2 paragraphs contradict your first sentence
//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
I don't see how. I simply compared/contrasted them. To paraphrase:
Parametric = less bands, but more precise control
Graphic = More bands, but less precise control
Choose your favorite flavor.
kizz
kizz
omaha, ne
adam71
