nuts and bolts, ****...its just plastic:laugh:i use nuts and bolts with foam tape to seal it
Ill prob just put the flange lip on the inside and use same foam tape too
very true..I may try that with some washers so the plastic hold up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifi put flange on inside as well but if you screw it after a couple of changes the wood will be fraged
and i'm only talking 1/4" bolts not very big
hmmm not sure how it would like it off the powerTry tuning the AQ to 30 hz. It's worth it. I was really surprised.
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifnice rising sun on your box buckwanna build me one ??
Well turn the gain down some then. I have about 1500-1600w going to my hdc310a in a 1.5 cubic foot box tuned to 30hz and it plays a nice 29 hz test tone. Can't go lower than that with a test tone on full power.hmmm not sure how it would like it off the power
with my hdc3s I tuned to 35 and they liked it, just hope the hd3 suspension is better:crap:
very nice to know....basic boxes for now...should be startin tonightFor external aero's you should put the flange on the inside of the box, will make a smooth transition.
and most 6th orders made for SPL have shitty power handling out side of a specific bandwidth because the sub will unload. And that dude with the 6th order for the AQ 15" didnt even break a 140 iirc, so I wouldnt be idolizing that build.
