Gm ho alt 275
oxsign
No Affiliation
Power Bastard 275
I have a Power Bastard 275 amp. It's got the 4 pin plug for a 4.3 (had it in my blazer). I also had it setup for a single wire hookup (also had it in my silverado).
$200 PLUS ACTUAL SHIPPING TO THE LOWER 48. Also looking for a motor I can recone. Pending the motor it could be plus cash. Just let me know whatcha got.
Depends where you live
IDK, but the plug is likely different. The 1 mounting tab is likely different and I think might be a straight up and down mounting, if it is straight up and down you can buy the front case half cheap and just change it, it's easy and I actually have 1 that I pulled off my newest alt to replace with the stock style mounting like this alt posted for sale.
Would it fit and work perfectly on a 1994 chevy silverado 350 5.7L? Very interested let me know asap
From what I just looked up, it appears that the mounting location is the same. But the 1 mounting foot is much thinner. I would suggest that it would mount so long as there is room for the thicker 2" wide foot. Other than that the plug is prolly deff diff and not sure how the alt is set up electrically, however a regulator would fix that since there is many electrical connection configurations for this alt to work in just about anything. Its worth looking at.
What does your alt look like from the front? Are the "ears" on the sides or toward the bottom like this one? I can measure center from ear to ear if that would help.
well thanx for the timely PM ..... just ordered a brand new dual/tri set up from ohio geterator with 275 amp alt / belt /and pully
would have been glad to give you cash and p/u .......but oh well....... GLWS
oxsign
No Affiliation
oxsign
Orlando, FL
oxsign
