Glass Window
Black Truck 10
I am planning on putting a glass window on the inside of my sub box. I am curious as if it will sound different by using Lexan or Plexiglass rather than MDF or birch. I only want it for the front of the box. I would put it in a frame and everything.
The glass would be about 10 inches tall and 48 inches wide.
If I used Lexan I can get it in 1/2 inch
If I used Plexiglass I can get it in 3/4 inch
Which should I use, I want the most out of my new SI Mags?
Ya it is big, but I was thinking since I found out its better to have 2 seperate chambers for the subs that I would just cut it in half and then I would only have 2 24'' pieces.
To add another question if im running two si mags sealed do yall agree to have 2 seperate chambers or 1 big one? Would 3/4 plexi still flex at 24 inches wide 10 inches tall?
My box is 24x12. I chose 3/4 inch plexi.
Seperate chambers would probably be better just incase one sub doesn't really take away from the other.
Black Truck 10
Black Truck 10
Houston, Tx
shortyg83
