Giveaway time! Reply to enter: Stage 1 Wiring Kit
I hope not. Fuel pump was replaced less than a yr ago. Sounds like it's not getting gas.....but gas gauge shows 3/4 full unless someone cyphened my gas again. It sure wants to try but.....man sometimes I wish I was a mechanic.
could be coil packs, they easy,, if not starter.. we had to replace something on wifes old car like a fuel pump sensor or something 2 yrs after we did the fuel pump..
Older tahoes have a distributor not coil packs.
Sent from my Moto G4 using Tapatalk
What brand did you install before?
Airtex brand goes bad fast so delphi is recommended.
If its cranking but wont start then it could be the fuel pump or fuel injectors.
Honestly, not sure since my mechanic replaced it. Funny you mention Delphi, I just got done replacing the EGR valve.....it was running really rough and my wife happened to talk to mechanic about it and suggested the egr valve. Delphi brand.
I plan to block off the egr valve, just need a tune for it so i dont get a code.
The intake is dirty as cr4p from it, i will only lose 1-2mpg from it anyway.
Got told it won't start unless muffler piping is connected to the cat...not sure if I should believe that or not.
Normal for chevys. //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
Don't make me send some cold weather your direction //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Hillbillys run open headers for the sound lmao..
You lose mpg when the piping isnt connected since you lose back pressure
Back pressure is a myth.
Not in larger motors and turbo setups..
Stock setups have no use of back pressure so it wont affect anything, but in my case with a 5.7l the back pressure is a restriction for power but a gas saver.
popwarhomie....your missing out on a new thread 4 diff branded 10's and diff branded 12's in same vehicle lol
Oh God.. Kinda like how everyone says EXO is so smart and knows everything car audio related.. That tard was running 2 18s and 2 15s not that long ago and told everyone to run peal and seal.. People at slamfest wanting to take pics with him and shit for some reason. I guess I just don't understand "celebrities".. Rant over.. lol
here ya'll should like this... i finally signed up on fb just to see car audio stuff and i had just been on advance website so i listed my birth date as 2004 and it won't let me change it cause it thinks i'm a kid trying to act older.. so i have my picture on it but it says i'm 13 lol..
GPcarAudio.com
Pro Seller
Supporting Vendor
GPcarAudio.com
Missouri
