Get your DMM excel spreadsheet to help determin Voltage and/or output watts
  • 2
realdragonluv
I put together the attached Excel spreadsheet where you can calculate either the voltage output with the desired watts and speaker impedance or to determine the current watts given the DMM AC voltage and speaker impedance.
Simply enter the values in the yellow cells and the results will display in the green cells. I hope this helps someone who may be confused with the worded instructions available.
To use this you need to use a Digital Multi Meter (DMM) set to AV voltage setting and hook it up to your amps speaker output.
DMM_settings.zip
  • DMM_settings.zip
Try this other test; get a 3.5mm headphone repair cable and connect it to the LC7i input. Connect that to your phone and measure. This will tell...
913
realdragonluv
realdragonluv
United States
dunerider650
    May 22, 2024
    May 22, 2024
