Get rid of FM buzzing?
Grounds are good...sanded to bare metal and greased over connections to prevent rust. For my big 3 though i used the factory chassis ground which goes to the fender brace which is part of the frame. Think i should change out the other grounds? (the ones that are braided wire)
Also for my 2nd batt i have a positive run from the alt to it, then a neg run to the other batt, which is about 6ft. Should i ground my 2nd batt to the chassis too? They are both under the hood.
I Like Waffle
North Carolina
JimJ
