Always Ran Under a Liquid Cooled Waterblock and NEVER Saw 35 Degrees C. and NEVER OCed So it is Still Under Warranty For Over 2 Years Yet!!
• AMD FX 60 with Box and Fan Toledo Core 939 Pin 2x1GB L2 Cache
• MSI K8N Neo4-F Socket 939 NVIDIA nForce4 ATX AMD Motherboard - R
• COOLER MASTER Ammo 533 RC-533-SWN1 Black/Silver Aluminum+Plastic front bezel; SECC chassis ATX Mid Tower Computer Case - Ret
• Custom TopPower XScale 750 Watt SLI Ready Power Supply from Performance -PCS.com Over 280.00 Dollars One of the Best Found Anywhwere with Combined and Split Rail Switch.
• G.SKILL 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Kit Desktop Memory - Retail 2-3-2-5 1T
• Seagate Barracuda 7200.9 ST3250824AS 250GB 7200 RPM 8MB Cache SATA 3.0Gb/s Hard Drive - OEM
• NEC Silver 16X DVD+R 8X DVD+RW 8X DVD+R DL 16X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2M Cache IDE/ATAPI DVD Burner - OEM
• Thermaltake Bigwater SE 12cm Liquid Cooling System
• Mitsumi 1.44MB 3.5" Internal Floppy Drive Silver
• Windows XP 64 Edition with COA License and CD ,newest BIOS Flashed.
• MSI Nividia 7900 GForce 256 Mb
• This is one Slick Computer and a very fast and very stable Plus a fantastic 750 Hi Performance Power Supply. This Mother Board a single Slot 16 x and a Cmos Button instead old shorting the two pins. This makes it easy for you overclockers in case the CMOS needs clearing. Plus this board is very OC friendly.
$1100
The FX60 Chip alone is over$600 Retail
I only used this for 3 Months
$1100
