Sold Fuzion FE-504 NIB
neonknight
Fusion is an Australian company that builds high end car audio gear that is very reasonably priced. You get a build quality and performance level that is normally found on top of the line amps. is a 4 channel design with Mosfet outputs. Uses the priopitary FUZION power regulation technology. Power output is 50 wpc into 4 channels at 12.6 volts and 140 wpc into 2 channels at 4 ohms. amp is 2 ohm stable.
Has variable bass bost + 18 db
Low and high pass x over 18 db per octave
4 guage power connection
This amp is brand new in the box, never installed. Originally sells for $400, so for $125 you wont find a better performing amp. If you need a great sounding amp, and are on a budget, don't let this one pass you by. Questions? Call 509-588-4196 or 509-528-0910. Send emails to sher.lock@urx.com Paypal users add 3%
neonknight
neonknight
benton city ,wa
neonknight
