Sold Fusion NV-AM25001
k_schutte
$250 shipped... Fresh refurb from Fusion, still has 9 months of warranty left, only about 20 minutes of play time since I got it...
Bi-Metallic Thermal Venting System
Features two levels of heat dispersion through a combination of alloys with complimentary thermal transfer properties
One-Piece Cast Structure
This reinforced bi-metallic cast structure provides extreme strength, rigidity and protection in the extreme SPL ranges
Recessed Anchor Points
Robust industrial standard mounting feet with discretely recessed anchor points to provide clean, secure and resilient installation
Multiple Fuse Protection
Multiple fuses protect internal components and are easily accessible for quick changes in a competitive environment
Product Specifications (under rated)
825 Watts RMS x 1 Channel @ 4 Ohms and 1% THD+N
1310 Watts RMS x 1 Channel @ 2 Ohms and 1% THD+N
1790 Watts RMS x 1 Channel @ 1 Ohms and 1% THD+N
tested and proven to put out over 2200 rms @ 1ohm
Max Power Rating: 2500
Max Current: 218A
Full Rated Power Distortion (Max) 1kHz: 0.43%
THD @ Rated Power 1kHz/100Hz: 0.3%
Frequency Response Hz (-3dB): 10Hz - 250Hz
Signal to Noise: >90
Variable Low Pass Filter: 24 dB/Octave
Bass Boost @ 45Hz: 12dB
Input Sensitivity: 0.2 - 8V
Input Impedance: 47K
Fuse Rating: 200A External
Or as a partial trade for more power, i'd love a DD Z1, or something similar... don't want to add much more than like $300-$400 though...
k_schutte
k_schutte
cedar rapids, IA
k_schutte
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
